Feb 2022
1 / 37
Feb 2022
Apr 2023
Starting up this thread to give updates on my newest build. The build will take place in my 2007 Nissan Sunny N16. This is a continuously evolving build so new products will make their way into the car
Source:
Pioneer DEH-X7800DAB
Front Stage:
Helix F62C 2-Way Components
Rear Fill:
RECOIL Level 3 2-Way Coaxials
Rear Stage:
Helix P12
Full Double Baffle Sealed Enclosure with Deadening and STEG S7 padding
Amplification:
HERTZ HCP-4D
Wiring:
Stinger Pro Series 4 Awg Power - GND Wires
GroundZero 2 Awg Big3
GroundZero GZCC 3.14m RCA cables
Kicker 12 Awg hypertwist tinned OFC Speaker wiring
Oehlbach 12 Awg OFC Subwoofer wiring
Sound Deadening:
Infinity Sound Deadening Sheets ( Floor + Roof + All Doors + Rear Shelf + Trunk + Boot )
Closed Cell Foam Dampening ( Floor + Door Cards + Rear Shelf + All Plastic Panels )
3M Fastrings
Battery:
60 Amp Wet Battery
  • created
    Feb '22
  • last reply
    Apr '23
  • 36
    replies
  • 4.4k
    views
  • 4
    users
  • 17
    likes
  • 6
    links
Sound Deadening / Dampening
Starting off with the sound treatment of the metal panels. This is done by stripping the car to the bare metal, cleaning it with a isopropanol solution and having a clean surface to work on.
Got my hands on some Infinity & Caliber sound deadening sheets and got down to working. Most of the work was a DIY apart from a few finicky areas where I got tired and just let the installer do it. Most of my equipment comes from @soundvalley. I did utalize 1 sheet of a different branded deadener (Recoil) which is visible in the pics.
Once the panels were treated with the sound deadener, next we move onto the sound dampening material which in this case is Closed Cell Foam (CCF or Acoustic Foam). Got to use three different thickness of foaming ( 1.5cm, 1cm, 0.6cm. These were used on all the plastic panels inside the cabin after they too got treated with pieces of sound deadener first
Let the pictures do the talking:
1) 4 x Doors
2) Floor
3) Rear Speaker Shelf + C-Pillars
4) Roof
6) A+B+C Pillars
5) Trunk
Source: Pioneer DEH-X7800DAB
https://www.pioneer-car.eu/de/de/products/deh-x7800dab
Introducing the next generation of single din headunits from Pioneer. The X7800dab is full of modern day features. But most importantly, its a 3 way network capable headunit, had auto and time alignment, crossover settings with slope settings etc which make it a great headunit for any audiophile
There's no possibility for a double din headunit in the nissan sunny ( unless you go with a pop out headunit which i'm not a big fan off ) so will be sticking to a single din for the near future
Rear Stage: JL Audio 10W1V3-4
Being one of Crutchfeild's top selling subwoofer, you wonder why it's liked by so many with 5* ratings almost everywhere. It's simple. The sub uses the same patent technology JL Audio developed for their legendary W7 subwoofer's.
10" 4-ohm subwoofer
polypropylene cone with nitrile-butylene rubber surround
power range: 75-300 watts RMS
peak power handling: 600 watts
frequency response: 25-250 Hz
sensitivity: 84.2 dB
Some Pictures of the amazingly brilliant subwoofer from the mad people at JL Audio along with the all around double baffle mdf sealed box lined with Trent Sound deadening sheets and STEG accustic padding
Amplification: Hertz HCP4D
https://hertz-audio.com/product/car-audio-amplifier-hcp4d/
70 watts RMS x 4 at 4 ohms
130 watts RMS x 4 at 2 ohms
260 watts RMS x 2 bridged at 4 ohms (4-ohm stable in bridged mode)
CEA-2006 compliant ratings
Class-D amplifier technology
frequency response: 10-60,000 Hz
variable high- and low-pass filters (50-3200 Hz, 12 dB/octave) on front and rear channels
variable bass boost (0-12 dB at 50 Hz) on rear channels
mono buttons allow 4 outputs from 2 inputs
preamp and speaker-level inputs
Automatic Remote Turn-on with speaker-level inputs
preamp outputs
fuse rating: 20A x 2
1 month later
Got the 3M Fast Rings. These are intended to isolate the midbass from getting lost within the door. The central ring (pic 1) goes right behind the midbass driver and the outer ring (pic 3) goes around it ensuring the music travels into the cabin and the cabin only. An additional outer ring was also bought for each speaker which was installed on the inside of the door (pic 2) ensuring the coil is protected from water and reducing unwanted resonance inside the door frame
ADVERTISEMENT
The main power/gnd wires will be the 4 awg Stinger Pro series tinned OFC cables. These will get covered in braided sleeving along with the correct sized ferrules and heatshrinks
https://stingersolutions.com/collections/power-wire/products/4ga-pro-power-wire-black-100-roll1
TRUE-SPEC tinned Oxygen-free Copper
Translucent colors
Hyper-twist construction
Ultra-flexible matte jacket
4GA- 1666 Strands
