Mar 2020
1 / 5
Mar 2020
Mar 2020
Asslam u alaikum.dear fellows my friends santro engine oil light start blinking while driving.we consulted a mecahanic he checked the wiring there was no issue.the wiring was ok.Then we consulted our regular mechanic he said it may me be a faulty oil switch or if not then the oil pump need to be changed.The electrician then changed the oil pressure switch with japanese one (sorry i dont know what that switch is called).Then after changing the blinking was gone.during this problem there was no reduction in acceleration and also we had checked oil level and it was full.(also in jan we had changed engine oil and filter and after that it was driven less then 100km).now after two weeks the blinking had started again.My friend is worried as mechanic told him that engine needs to be opened for oil pump replacement and some other parts has to be replaced and require some expense (recently he has spent almost 15k on gear problems)he is depressed and thinking of selling his car.can you guide what should we do, is this is due to oil pump or some other issue.kindly put some light on it.jazaALLAH khair.
  • created
    Mar '20
  • last reply
    Mar '20
  • 4
    replies
  • 1.5k
    views
  • 2
    users
  • 1
    like
Tell your friend not to be depressed, this is not a big issue. Maybe there's a faulty oil pump or it needs to be cleaned , not a very big issue.
If you are in Lahore, you can contact Mr. Sadat Masood at CarTech Autos near Johar Town for a second opinion. They say they are Santro specialists.
I had insisted him to change oil pump but the mechanics he consulted are telling him that your connecting rod is also making noise,so we complete open the engine to change it and rings should also be replaced(i did not understand why to replace rings when there is no blue smoke or oil engine)so the word "OPENING THE WHOLE ENGINE" is terifying him as this is his first car.by the way he lives in sialkot.
ahan, well than that's another scenario .. maybe he should take a second or third opinion also before going for the surgery ..
Plus he aslo told to replace oil pump.we have consulted 2 mechanics.yes you are right thats why we are not foing for surgery.i will ask him to contact with mr sadat.
