Hi, does anyone know, preferably from experience, if liqui moly injector clearer is a stronger cleaner to clean engine parts, or is the fuel system treatment stronger? I can't find the technical details anywhere. Also, are both PEA?
Also interested to know, have used injector cleaner twice,
From what i have been able to find out in the tech specs, the fuel system treatment is preventative treatment for newer engines, whereas injector cleaner is for cleaning off build up in older engine. But the tech specs are not clear about PEA...I guess will have to use both over time and compare the results.
Which one is better to clean dirty jets of a 2010 Corolla?
