Mazda USA doesn't allow the use of synthetic oil for warranty support on rotary engines, it will void the warranty.
Japan, Europe and all other countries suggest synthetic oil.
Mazda's rotary racing teams run synthetic oil.
If you have less than 30,000 miles on your motor and haven't used synthetic yet start now if you like the pro;s more than the con's. From what I hear, either or is good on a new motor. If you just rebuilt your motor use non synthetic mineral oil until you break it in, then switch to syn. Syn inhibits new star-ups.
Syn makes the ruber seals swell in motor which is a good thing on new rubber.
If your motor has alot of miles on it, your engine has carbon build up that aids in sealing the motor. Syn's cleaning properties will remove all of that carbon build-up. Your small leak may become larger.
