So I went to AutoExpress Lahore for wheel alignment issue, as the car (WagonR) tilts towards the left when steering is straight, they analyzed it with their machine and pointed out that camber is out, the angle was ~1.31 degrees on the left front wheel. They said, it's better to adjust the camber first and then do wheel alignment, and the charges for camber adjustment is 4000 PKR.
Wanted to ask, if the charges are reasonable and the shop is good enough for the work or should I go to other shops in Lahore?
