Originally published at: https://www.pakwheels.com/blog/what-is-beadlock/
In the previous article, we told you about winter tires, why they are important and different from summer tires. Now moving forward, one must adhere to the fact that tire is one of the most important parts of every vehicle and needs proper care and attention. So that is why in this article we will tell you about beadlock, and its importance.
First off, what is a beadlock?
Beadlock is a mechanical device which secures and bite the bead of the tire to the wheel of the vehicle—in simple terms; it means that at times where the tire pressures are insufficient, to properly hold and sustain the bead of the tire a beadlock is an essential accessory or product.
Before going any further, it would be worth mentioning here that there are several styles of beadlocks—meaning different for cars and motorbikes. For a tire and wheel of the 4-wheel vehicle to stick together and work properly, seamlessly a ring like a thing is used which is infused with a larger number of bolts around its circumference. While on the other hand, the beadlock which is used for motorbike is a curved plate; tightened by a single bolt. The dodged military truck used the first beadlocks.
Importance:
- Beadlock ensures that the rim and tire rotate at the single time.
- It prevents the tire to slip when inflation pressure is low.
Moving onward, it is pertinent to mention here that a base beadlock is designed to glue the tire bead between an outer and inner ring. The outer ring is bolted into the inner ring with bead clamped between them.
Download PakWheels App
It is advised that always take care of your tires properly other they will wear out faster and you have no choice but to change them, so to save money always take care of your tires. This was a brief overview of beadlock; we will bring you something more exciting regarding tires.
Stay tuned for more updates and share your knowledge and thoughts in the comment section below.
