Series 18 DC
Heavy Pulling Power of up to 18,000 lbf. (single line)
- Dependable high-torque series-wound 24V DC electric motor
- Weatherproof industrial contactor control pack
- Rugged 32' (10 m) industrial remote control
- Disc brake designed for extended power-out use
- Thermal overload switch protects motor from overheating
- Wire rope, roller fairlead, and tensioner sold separately
- Click here for winch accessories4
<table width="100%"><tbody><tr><td class="title3">18 DC SPECS/PART NUMBERS</td> </tr> <tr class="altrow" height="18px"> <td>Part Number: 72005 - 24 Volt</td> </tr> <tr height="18px"> <td>Rated Pulling Force: 18000 lbf (8165 kgf)</td> </tr> <tr class="altrow" height="18px"> <td>Drum Barrel Diameter: 4.0 in (102 mm)</td> </tr> <tr height="18px"> <td>Drum Flange Diameter: 8.24 in (209 mm)</td> </tr> <tr class="altrow" height="18px"> <td>Distance Between Flanges: 9.95 in (253 mm)</td> </tr> <tr height="18px"> <td>Recommended Maximum Wire Rope Diameter: 1/2 in (12.7 mm)</td> </tr> <tr class="altrow" height="18px"> <td>Recommended Minimum Wire Rope Breaking Strength: 26600 lbf (12066 kgf)</td> </tr> <tr height="18px"> <td>Approximate Shipping Weight: 103.0 lbs (46.7 kg)</td> </tr> <tr class="altrow" height="18px"> <td>Duty Cycle (intermittent per SAE J706 section 6.2): 40 ft (12.2 m)</td> </tr> <tr height="18px"> <td>Mounting Bolt Torque: 35 - 40 ft*lbf (47 - 54 N*m)</td> </tr> <tr class="altrow" height="18px"> <td>Maximum Layers of Wire Rope: 3 (with 1/2" dia. rope)</td> </tr> <tr height="18px"> <td>Gear Reduction: 315:1</td> </tr> <tr class="altrow" height="18px"> <td>Brake Type: Disk</td> </tr> <tr height="18px"> <td>Contactor / Remote Type: Industrial contactor with 33' (10m) heavy duty remote</td> </tr> <tr class="altrow" height="18px"> <td>Standards Compliance:
SAE J706
CE Machinery Directive 98/37/EC and 2006/42/EC
CE Electromagnetic Compatibility 2004/108/EC</td> </tr> </tbody></table>
<table class="accs" width="100%"> <tbody><tr><td class="title3">ACCESSORIES</td> </tr> <tr class="altrow"><td height="18px">Wire Rope Tension Plate 10'': PN 31149</td></tr> <tr height="18px"><td>Fairlead Black 10'': PN 24336</td></tr> <tr class="altrow"><td height="18px">Fairlead Chrome 10'': PN 30859</td></tr> <tr><td height="18px">Remote Clutch Mechanical: PN 38316</td></tr> <tr class="altrow"><td height="18px">Remote Clutch Air: PN 71370</td></tr> <tr><td height="18px">Wire Rope Assembly 1/2''x75' EIPS: PN 77534</td></tr> </tbody></table>
<table class="specs" cellspacing="0" width="100%"> <tbody><tr> <td colspan="8" class="title3">24V PERFORMANCE DATA BY LAYER - 1/2" (12.7 mm) dia. rope</td> </tr> <tr> </tr><tr class="altrow"><td>Drum Layer</td> <td colspan="3">Line Load *</td> <td colspan="2">No Load Line Speed</td> <td colspan="2">Drum Capacity</td> </tr> <tr class="altrow"><td>
</td> <td>lbf</td><td>kgf</td><td>kN</td><td>ft/min</td><td>m/min</td><td>ft</td><td>m</td></tr> <tr><td>1</td><td>18000</td><td>8165</td><td>80.1</td><td>18.5</td><td>5.6</td><td>20</td><td>6.1</td></tr> <tr><td>2</td><td>14727</td><td>6680</td><td>65.5</td><td>22.2</td><td>6.8</td><td>45</td><td>13.7</td></tr> <tr><td>3</td><td>12462</td><td>5653</td><td>55.4</td><td>26.7</td><td>8.1</td><td>75</td><td>22.9</td></tr> <tr><td colspan="8">
* Never exceed the Rated Pulling Force. Installation of a Rated Capacity Limiter is recommended.</td></tr> </tbody></table>
<table class="specs" width="100%"><tbody><tr> <td colspan="6" class="title3">24V FIRST LAYER PERFORMANCE</td> </tr> <tr class="altrow"> <td colspan="2">Line Load</td> <td>Current Draw</td> <td colspan="2">Line Speed</td> <td>Duty Cycle</td> </tr> <tr class="altrow"><td>lbf</td><td>kgf</td><td>Amps</td><td>ft/min</td><td>m/min</td><td>min/10min</td></tr> <tr><td>0</td><td>0</td><td>58.1</td><td>18.5</td><td>5.6</td><td>4.3</td></tr> <tr><td>3000</td><td>1361</td><td>104.0</td><td>11.0</td><td>3.4</td><td>2.0</td></tr> <tr><td>6000</td><td>2722</td><td>137.8</td><td>8.6</td><td>2.6</td><td>1.5</td></tr> <tr><td>9000</td><td>4082</td><td>169.4</td><td>7.1</td><td>2.2</td><td>1.2</td></tr> <tr><td>12000</td><td>5443</td><td>209.7</td><td>6.0</td><td>1.8</td><td>0.9</td></tr> <tr><td>15000</td><td>6804</td><td>253.2</td><td>4.9</td><td>1.5</td><td>0.7</td></tr> <tr><td>18000</td><td>8165</td><td>278.2</td><td>4.6</td><td>1.4</td><td>0.7</td></tr></tbody></table>
