Some very Old Post from the club!
12 Easy Tips To Increase Your Car Mileage
Tip 1: Do not accelerate too fast
Too quick acceleration consumes too much fuel, accelerate slowly and gradually. That will save quite a
significant amount of fuel in city driving.
Tip 2: Do not use clutch too much (Stick Shift Only)
If you use a manual transmission car, as is mostly used by people in Pakistan, do-not
drive with clutch pressed, or use clutch only when needed, too much use
of clutch will waste a lot of fuel.
Tip 3: Change gears appropriately (Stick Shift Only)
This is also applicable for manual transmission cars. Use correct gears at correct
speeds; this will help save the fuel. For correct speeds, see your car’s
user manual.
Tip 4: No Excuses to delay car service
Get the car serviced as per manufacturer’s recommended schedule. This will ensure good health of
engine, less maintenance due to break-down.
Tip 5: Do you drive in dusty environment? Clean the Air-filter
If you drive in dusty environment the air-filter gets filled with dust and
makes the engine suffocated. Clean the air-filter more often than the
service schedule (say every 5000 KM or so), this will help the engine
run more easy and consume less fuel. Trust me, it’s going to really
help.
Tip 6: Red-Signal Ahead?Put the feet off the accelerator
If you are sure that you got to stop after next 100 or 200 meters due to a red
signal, keep your feet off the accelerator and car will slow down on
engine’s resistance, saving on fuel as well as the brake shoes, apply
brakes only when about to stop. This is a great help to save that extra
drop of fuel.
Tip 7: Air Pressure in tyres
Get the air-pressure in tyres up to the recommended pressure, and check it once at least in 15 days, it
helps the car run smooth and drink less fuel.
Tip 8: Try to keep a constant max speed
When driving in a city or highway, try to maintain a constant speed, that will help the engine put
less effort to accelerate or decelerate unnecessarily. This will help
reduce fuel consumption.
Tip 9: Keep the window’s glass rolled up on highways
Driving with AC on and glasses rolled up will actually help the car move easy because
when windows are open, the car faces more air-drag due to cross
ventilation through car, thus consuming more fuel. So always try to keep
windows rolled up specially when driving at high speeds.
Tip 10: Buy fuel during morning hours
Buying fuel during morning hours makes sense, because the fuel is a liquid and cools during night
hours as temperature is low, and it becomes more dense, so in night
hours, you get more weight of fuel for same litres, so its like a
bargain in fuel amount
Tip 11: Re-fuel your car when tank is close to half
This will help reduce the vapors formation in tank, which moves out as you open the
lid to re-fuel, thus saving some amount of fuel in the tank.
Tip 12: Clean up the crap from the boot-space
Remove any unnecessary luggage or stuff that you don’t need from back space, that
will let the car feel light and run easy on less fuel.
Save fuel, burn it less, save economy and environment both, for a greener and cleaner tomorrow.
(Copied)
