Hi Pak Wheelers today i am going to share a review of a rubber spray paint brand " Veslee "
Sprayed it a week ago
I live in Islamabad and i was at workshop for some work on my Mehran so just saw this spray at a shop previously seen it at online stores but was not willing to spend 700 or 800 and worrying about results so I got it for Rs 350
suggestion : if you use newspaper for keeping paint away from other parts try to not throw the newspaper because there are some Islamic word written or most of them have Pakistan name and other religious things on them too so keep them in safe place
1st Step : Preparing the surface , I used normal dish washing liquid as it removes all of the wax from it and for more usually people use " Isopropyl alcohol / Rubbing Alcohol " but as it was expensive a little so I used a Perfume so each and every place has Alcohol remove despite I dont have a good paint Job done on my car and the wax I used is not too good but stilll tried to clean it
2nd Step : prepping to make sure that I would not have to strip off the rubber after the paint work
step 3: Clean the surface once again before spraying
Coat 1 :
Coat 2
Coat 3
final coat
there was One more Coat done afterward so didnt took the snap so you may have to do almost 5 coats and I would Recommend you to buy 2 Cans as I did and my place was open but there was air so was little bit difficult in spraying chose a closed and dry place.
Another Important Recommendation is
be patient when spraying as you spray the first coat you may feel its not sufficent but dont respray let each coat dry for 10 minutes
Also read the Instructions carefully
Shake the Can well for 1 minute before applying each Coat
Final Verdict
- Dont think that it would be same as Plastidip it is a cheaper product so it has a lower quality
- It is easily peel able so dont worry about the paint quality and any other damages
- Do use if you are thinking to use it not more than 6 to 8 months
- it wont be able to handle major scratches but might be able to handle minor one
- Dont apply any wax intentionally or unintentionally on it as it would make it easily removable
- As compared to wrap if a wrap tears apart you cant fix it but if this Rubber Spray peel from any part Respray it and would be good again
