Apr 2007
1 / 15
Apr 2007
Nov 2007
Dose anyone here know the unlock code for TV/DVD Command applications of S-Class (W221).My uncle needs to unlock his cars front TV/DVD, the option is know as “Driver Distraction”, which needs to be switched off.
@Storm Bhai
I have gone through few unlocking tips on the web, need to confirm if its harmless to change company settings.
  • created
    Apr '07
  • last reply
    Nov '07
  • 14
    replies
  • 14.0k
    views
  • 1
    user
  • 1
    link
If I remember correctly there's a mute/end call/service button trick. I cannot say it'll work on your W221. It'll get you to the engineering menu where you can change driver distraction.
Be very careful what you do in the engineering menu. Whatever you change, change it one by one and always write down what you changed just in case you have to reverse it.
Reply By : anonpak on 4/27/2007 11:14:40 PM
Thanks dude,i will be waiting for the engineering meni.
@Rocketman:
Basically,Its a cheat code.
if you want it done and don't want to do it yourself take it to the dealer and they can unlock it with the starmakr computer, it only takes a few seconds by changing the settings on the scroll down menu. not too sure how much they'll charge though. should ba cheap.
@Storm Bhai:
The guys at Shahzawaz told me that they cant disable the option.On the other hand they said that it can be unlocked.
Daniyal, the best thing to do is go back to dealer and have your uncle or father tell them to unlock it. They'll resist a bit but their computers are the safest way to turn off driver distraction.
If they continue refusing, hold the mute/end call/service buttons together. In previous MBs this would get you into the engineering window. Let me know if it works on your W221.
get it some lassi n relax...it will sleep n will b okey after some time...
no harms..just kidding
7 months later
ADVERTISEMENT
