Salam,
Which tyre should I put in my upcoming Toyota yaris. The size of bg traco plus 185/60/r15 is okay but i want a noise less tyre. Which company tyre should i opt for?
Many options...
YokohamaDunlopGoodyear eaglesports
All are good...I recommend you also try Goodyear eaglesports...they are good as well...
Btw...can you also give us a review of the Yaris and how it drives after you get it...
Go for Yokohama Advan Db. It will be available in same size
Sure brother why not
Does Advan db come in 185/60/r15?
Yes. It's stock tyre for Suzuki Swift. Size is 185/60/R15
If this is your priority, then Yokohama Advan dB series is your only solution I think, however, keep in mind that the wear rate of tyres may then be comparatively higher.
Assalam ao alikumI have purchased yaris 2021 and changed tyres 195/65 R15Mechllen tyres brand newTyre are excellen no noise road grip is good.Car gain some more height I am very much satisfiAt speed of 80km/L without Ac car gives 26km/L on longIn city 16With ac 20Km/L on longAnd 14 in city.Tyre pressure 25 in all tyres.
WS. Please put correct tire pressure for performance. 25 psi is low. You will have better wear, stability and mileage with the correct pressure. BTW 195/65 is a bit large for the Yaris and will probably put stress on your suspension.
Share pics so we can see how they look in this size on yaris
Advan DB is a good tyre overall, but I don't think it performs well on rough roads. See if you are considering this point as well.
What about changing Yaris tyres to 185/65 R15.....will it result in any improvement in drive?Has anybody installed this tyre size in Yaris?
I would recommend Zeetex or Otani if you want a value for money tyre. Extremely quiet and comfortable. If you have a bigger budget, then you can't go wrong with Michelin's. But buy only from official distributors. Smuggled tyres are very common. Contact Zafar Enterprises who are sole importers for Michelin in Pakistan (021 111 938 938).
Did you get any answer to that? I recently shifted from Suzuki swift (2015) to Yaris (2022) the road grip of swift beyond 110km/h was way better. I wonder what Yaris was missing I think the width of the tyre (default size 185/60/R15) and maybe the car ride height is way too high. I was wondering maybe 185/65/R15 will be fine. Have you ckd it?
Where can I get them? Used otani ek1000, heck of a tyre but can't find it again.
Call Zafar Enterprises (111-9389-38) who are the official importers. They will guide you to their authorized dealers
Price
