I have toyota vitz 2013 (1KR-FE engine) 170000 km driven. Maintaining car at soyota eastern since last two years. Six months ago check engine light appeared after getting it serviced from there. I sent my car back for dignose. After inspecting they told me that the downstream O2 sensor is not working so i went to a local electrician at jamshed Rd to get a second opinion, he said the same so I replaced O2 downstream sensor. Then I went to toyata eastern again for diagnosis because check engine light was still on. This time they said that "why did you replaced sensor it was ok now it says that your upstream sensor is not working. I replaced that too but it didnt worked for me too. I also used liqui moly catalytic converter cleaner. I have been resetting the ECU using obd II scanner but noticed that the light appear back around every 50 km. I went to toyota eastern third time for diagnosis this time they said that your engine rings are getting weak. I came to a conclusion that they didn't diagnosed properly or they don't know how to. They replace O2 sensors on false diagnosis.
Replaced O2 sensors (up stream and downstream both) Cleaned catalytic converter no leakage. Complete EFI cleaning done and spark plugs were replaced with the new ones. Engine is quiet and smooth but a little bit vibration when it's on idle.
Any suggestions what to do and do anyone know a good workshop for proper inspection as solution for the said error code?
created
Mar '18
last reply
7d
- 59
replies
- 10.0k
views
- 11
users
- 9
likes
There are 59 replies with an estimated read time of 3 minutes.
