Hi everyone. I also have Toyota fielder hybrid 2016. You should follow few steps after 60,000km mileage.
* clean the throttle body.
* indent preformatted text by 4 spaces
Must clean/service the hybrid battery fan before starting every summer season.
* Must service your complete hybrids battery after 80,000km mileage.
* Must change the brake fluid every after 1 year(max).
Note: Toyota use Dot 3 brake fluid but when you change it then you should go with Dot 4 brake fluid.
* service the brake disc n pads.
* change your spark plugs after 90,000km mileage.
Note: Use original laser iridium plugs.
* Must change coolant after 150,000km mileage.
* Must change transmission fluid after 60,000km mileage.
Note: Toyota axio/fielder hybrid must use ATF WS fluid. It’s not CVT transmission. Non hybrid uses CVT fluid for their cars.
Note: Your car must be 100% cool down before changing transmission fluid. Temperature falls in between 40 to 80 degrees. Means not less than 40 nor more than 80. Ideal temperature is in between 55 to 65. Must use scanner for temperature check.
* Always use Original Air filter.( helps to minimise engine sound)
* Make sure your engine and converter should be cool before changing engine oil. Engine oil Capacity(3.7 Litres)
Note: Always use -0W20 for new cars. After 150,000km switch it with 5W30.
Note: Don’t use engine oils that last more than 5000km. Reason: In Pakistan there is a lot of dust. Which make engine oil dirty faster.
* Must include injector cleaner in your fuel tank after every 25,000km. Make sure when you top up your fuel tank then include it. For best results use it before going to long route.
* Must clean your car’s Catalytic converter after every 50,000km mileage.
* Make sure that your tank should not go to reserve limit. Always top up your fuel tank when it comes to half.
Note: Always do research before doing any car work.
Google will help you a lot.
Also use car manual book for instructions. Download google translator app for translating Japanese to English.
