Aqua user here . i have 2014 model L package, self import from japan -
my vehicle has done 230,000 KM + on the ODO and going great. fuel average is still excellent and i face no issues
i have recently experienced ABS issue in my car and got it fixed. in this write up, ill explain this common issue and how to manage it . Usually, people panic once the dreaded ABS check light comes and they hurriedly sell their car. !
. what is the ABS system in AQUA?
all JDM vehicles have standard ABS . as we all know, its a safety feature and prevents wheel lock up on hard braking.
now on the AQUA( and prius) , the ABS system is actually a dual motor assy with electronic controller. the system is more than an ABS system and it does the following functions:-
A ) the ABS pump operates the anti lock algorithm for the brakes
B) the ABS pump operates the stability control algorithm for the Traction control system - this system helps with grip under adverse conditions
C) the second motor on the ABS pump harnesses energy from the regenerative system while braking and charges the HV battery ( the charging bars on instrument cluster you see going down while braking is actually the ABS motor working as a dynamo and charging battery)
D) the ABS pumps helps with assistive braking and applies appropriate pressure to brake booster to ensure smooth braking feel which is characteristic of these hybrid vehicles
E) the ABS pump operates the brakes to kill speed when we RESET the cruise control switch ( down )
why does the ABS system fail ?
as we can see, the ABS motor is a critical safety system and works constantly while driving
naturally, this being a mechanical system, the ABS motor fails after use and we get the dreaded ABS light, Stability control light and cruise control light . also , battery doesnt charge on braking so you get less fuel mileage !
the system on my aqua failed at 225,000km / - after nearly six years of use.
i have debated this issue with many. some blame it on brake oil, some on brake replacement job not done properly, etc
my take is that this is a serial defect and fails rather early by toyota standards
OK, how to fix this
very simple . just get the ABS pump and Brake booster pump assy replaced . you will need to replace BOTH systems .
call me for details . i got my system replaced from an excellent mechanic in lahore , model town. the gentleman imports the ABS pump from japan and doesnt do the kabli work
DM me for assistance . telegram ID = @Blueazure4u
https://tinypic.host/image/WhatsApp-Image-2023-07-13-at-15.43.40.2O6xX
^^ the ABS motor and brake booster assy
