I own a Toyota Vitz 2009 with 1kr-fe Engine with 138k on the meter. The engine is consuming oil and giving bad milage like 6 km per liter black smoke on higher rpm car feel underpowered so need your opinion what to do. As I am from Quetta and the only thing I have been told by the mechanic here is that it cant b rebuild Engine swap is the only way to go but I think if I go to Karachi I would be able to find someone who can Overhaul this engine. So need your opinion on this matter.
It's pretty common for mechanics to try to avoid overhaul because swapping with a used engine takes less work and time. Overhaul is the better option, Just make sure to use high quality parts.
Only if you can find a good machinist and a mechanic who knows his tolerances and torques. I mean a mechanic who knows his shit.
And that mechanic is @rajaatta at ijp road pindi
I heard about this guy in garden town lahore who rebuilds engines at his home. I for the life of me cant recall what that guys name was..
Edit: i think it was osama. Broski ka kafi naam suna tha
Yes osama is also on pw. Heard good of him. @capsat may guide u better further
110 Tipu Block Garden Town 0321 4106898 10 am to 7 pm week days only By appointment. Obama Car & Truck Centre diagnostics charges apply
Do you guys know any one who does 1kr-fe overhaul in karachi bcause i can't go to lahore.
Check with @babarhyd
Don't try rebuild anywhere in those areas, the machinery & machinist are lacking knowledge, so swap assembly. If you were from Islamabad or rawalpindi. Rebuild was very easy job from us & ata u rehman ijp.
So then should i go for a 1300cc engine swap ? Right now running 1000c 1kr.
If you can afford 1300cc swap than go for it. No mechanic in Quetta is able to overhaul 1krfe. They are good at rebuilding diesel engines only. In Karachi there are few mechanics but than again its not a one day job. So its preferred to go for swap. Keep the old engine and wiring intact so that with time and budget u can have it rebuild from Khi or Isb or Lahore.
Thank you guys for your input will go for 1300cc swap then because that's the only option here in Quetta.
I hv done vitz overhauled twice 1 was 2013 model other was 2011 tomorrow i will do 2006 model.engine all 1krfe but keep in mind boring is recommended if u want peace
In KArachi or where?
the best and safest option available in your circumstances.
karachi me kis c banwaya bro. any name snd contact details?
I hv my own setup just started 2006 vitz engine rebuilt today
ok good bro. do you built corolla engine as well ? 2nzfe ? and where is your setup
