okay the car weight and aesthetics are totally different from duet. It's bigger, wider and heavier. Second did you change the ecu too? Do you feel any knocking? You've done alot of alterations to your car which isn't everyone cup for doing (ustaad jees). Get your car for computer diagnosis and get a report, perform a compression test too. Tuning, tappet adjustment, oem Rim specs would do things better. What is the Health of MAF sensor? Are you using good oil and air filters?
