AOA,
I need little help with my Swift, 2011 braking system. I got the brakes changed in last Ramadan i.e. almost a month ago got the brake discs polished. There wasn't any sound after it, to my bad luck I want to DANISH MOTORS for an oil change and general service, I asked brake service as well. After almost 3-4 days while driving within the Karachi city brake padel got soft. I pumped the padel to bring it to normal and then drove home.
Since then a weird sound like squeezing appears at low speed when applying brakes, after around 5-6 km drive the sound turns into 'TUK TUK": when applying brakes. There isn't any sound on high speed and engaging ABS by applying emergency/hard brakes.
AS DANISH MOTORS when I saw brake oil was low I requested them to fill the brake fluid and they used GUARD's brake oil. On my complaint, they took a test drive and diagnosed that DISCs need to be turned again properly.
I have got the DISCs polished again from where I got it done earlier (Due to the COST factor) but the problem has again appeared after 2 days.
