السلام وعلیکم
Dear pakwheelers I purchased suzuki swift 2014 last month it's my first swift previously I owned vitz so I had found it's electronic power steering is hard, in right direction its little bit harder than normal but in left direction it's extremely harder than others eps (I personally comparing to the vitz eps) need guidance what should I check first are swift eps is normally harder than others brands like Toyota and 2nd thing I noticed sound and a little bit vibration in 3k rpm below 3k and up its fine and smooth in any gear, what should be the problem (I changed the clutch set and worn cv joint after that it's reduced but not disappear totally). والسلام
