there are two confirmed models , and will be displayed on 4th March Auto Show at Expo Center Lahore.
after the success of YBR125 suzuki is bringing back 125cc models in Pakistan
there are 2 confirmed and 2 unconfirmed models which might comes latter.
Unconfirmed models are Suzuki Mola and Suzuki Hayate
here are the details of confirmed models
Suzuki Van Van 125cc
Suzuki Van Van RV125 is an enigmatic bike. It is the favorite for Farm hands, gamekeepers, race teams and new generation. Suzuki Van Van RV125 is a bike that stands out from the crowd and one that certainly well above its weight and class and this new and stylish bike has launched in Pakistan.
Suzuki Van Van RV125 2016 model in Yellow Shape
Suzuki Van Van RV125 has a 4-stroke air cooled, single cylinder, SOHC engine with 125 displacement producing 11.8 hp. Suzuki Van Van RV125 seat is wide and spacious with low ride tight. It?s light and easy to ride with a tiny turning circle, aided by the wide bars. It has six speed gear box. It has disk brake at front and drum brake at the rear. Suzuki Van Van RV125 has great grip on the road because of its heavy tyres.Its top speed is 140km/hour.
Suzuki Van Van RV125 2016 new model various parts
Suzuki Van Van RV125 fuel tank is outclass and in charming shape. Its fuel tank capacity is 6.5 liters and dry weight is 118 kg. Its fuel type is injection and Suzuki Van Van RV125 is easy to start. Suzuki Van Van RV125?s build quality, gearbox, paintwork, power, tank size and mirrors all come in for some harsh word. It is economical bike due to cheep parts and low insurance also keep costs down.
Suzuki Van Van RV125 new model in white color with different logo
Suzuki Van Van RV125 2016 Price in Pakistan Specs Features
Suzuki Van Van RV125 Features:
- Powerful engine comfortable seat.
- Easier to use, normal price
- Powerful Head light solid front and back light.
- Good timing battery.
- Latest Suzuki bike with solid body.
- Classical design and color heavy duty.
- Stylish Graphics
Suzuki Van Van RV 125 Specifications:Dimensions and weights Overall length: 2140 mm (84.3 in) Overall width: 860 mm (33.9 in) Overall height: 1120 mm (44.1 in) Wheelbase: 1385 mm (54.5 in) Seat height: 770 mm (30.3 in) Dry Mass: 118 kg (260.1 lbs) Fuel capacity: 6.5 liters (1.4 gallons)Engine specifications Engine capacity: 125 cc Engine: Four-stroke, air-cooled, OHC Bore: 57 mm x 48.8 mm Compression ratio: 9.2: 1 Lubrication: Wet sump Ignition: Electronic ignition (Transistorized) Fuel system: Fuel injection Starter: Electric Transmission: 6-speed constant mesh Drive: ChainChassis specificationFront suspension: Telescopic, coil spring, oil damped Rear suspension: Swing arm type, coil spring, oil damped Front brakes: Disc brake Rear brakes: Drum brake Front tyres: 130/80-18 M/C 66P tube type Rear tyres: 180/80-14 M/C 78P tube type
Suzuki Van Van RV125 Price in Pakistan is PKR 129,000/.
Suzuki Thunder 125cc
Suzuki Japan is the leading manufacturer of the vehicle in the Pakistan. Pak Suzuki Motors is legally allowed to assemble and distribute the Suzuki Vehicles in the Pakistan. Suzuki thunder 125cc has been recently launched in the Pakistan by Pak Suzuki Motors.Suzuki Thunder 125 is the stylish and heavy duty bike of the Suzuki. Due to combination of its powerful 125cc engine it gives elegant result. It has 4-stroke single cylinder engine. It is perfect for road, leisure and club riding. Its speedometer is very attractive. Fuel tank has latest and beautiful graphics in attractive shape. Suzuki thunder 125 headlight also increases its beauty.
Suzuki Thunder 125 backbone type feels the comfortable traveling. Suzuki Thunder 125 has safe traveling because of its powerful breaks. Suzuki Thunder is the name of the quality and reliable in all sense. Suzuki Thunder 125cc includes all Suzuki vehicles has great resale value and can be sold at any time. Suzuki spare parts are easily available in all cities of the Pakistan.
Suzuki Thunder 125cc 2016
Features of Suzuki Thunder 125:
Specs of Suzuki Thunder 125cc:Engine :Type : 4 stroke, SOHCNumber of Cylinders : 1 (one)Cylinder diameter : 57 mmStep Piston : 48.8 mmCylinder capacity : 125 ccMaximum power : 11.28Ps / 9,000 rpmMaximum Torque : 9.4 Nm / 7,500 rpmDimensions :Overall length : 1,970 mmOverall Width : 745 mmOverall height : 1,045 mmAs Distance Between Wheels : 1270 mmDistance machine to Land : 165 mmEmpty weight : 130 kgFrame:Brakes Front / Rear Brakes : hydraulic disc / DrumFront Tire Size : 80/90-18 M / C 45PRear Tire Size : 90/90-18 M / C 51PTransmission:Transmission : 5 AccelerationTransmission Type : 1-N-2-3-4-5Suzuki Thunder 125cc 2016 Price in Pakistan is PKR 132,000/.
