Hi,
I bought a Suzuki Cultus 2014. 4 months back, driven almost 2000 KM after that, having no issue, driven upto Lahore from Rawalpindi. In Winter's heating gauge remains at the half position, I have Auto Fan but no thermostat valve, so it takes some time to get warm in Winters. Now, as the summer starts, I did radiator service and filled the coolant, replacing the normal water. I filled Guard 2 Liter coolant and 0.5 liter mineral water. I did the coolant testing by putting it in the fridge for 15 hours but it does not freeze, so I just did Antifreeze test and Coolant performed up to Mark, I am using Guard coolant, it was sealed packed, is it good to use because after filling it I haven't seen any decrease in temperature even when I go to mechanic to change the coolant, Mechanic while changing when touched the pipes, he said your car is getting OVERHEATED. Initially, after filling the coolant, there were many bubbles, but later on, I tested just fewer less when it starts, and then they die when the coolant gets heated up and tries to move outside of the radiator mouth. My Mechanic said the car is getting OVERHEATED, your head tapped needs to get tightened up. My needle remains in the middle, I counted it is at the 10th Line, I am confused, my car is getting OVERHEATING, I need to use the AC in a few days, so it would be an issue for me?
created
12d
last reply
6d
- 15
replies
- 221
views
- 4
users
- 17
likes
