AOA
Suzuki Alto VX (basic variant)
Dear All, by chance I booked and have been delivered local Suzuki Alto VX version. I wanted to install A/C in it and found from suzuki dealership mechanic that there is no A/C wiring available. As you know in Mehran VX version Suzuki use to give complete A/C wiring so that one can install A/C after market as well.
But in this case you guys know that Suzuki alto has ECU installed in it and A/C wiring must be connected with ECU of the car . also that ECO must be programmed to support air conditioner. So points are.
1-If there is no wiring present for A/C means that ECU is also not programmed to support A/C. and Suzuki is not expected to provide original A/C soon.
2-i got my alto checked from Local A/C mchenic, he says that we can install A/C without help of ECU which will cost arould 38K,
but here is the question.? when we switch ON the A/C than the ECU slightly increase the RPM/race of the engine and so that engine could bear the load of A/C.
If A/C is not connected with ECU than ECU will not increase race of engine that will make engine overheat and that will lead to greater problems.
Please share what can be the best solution for this.
Also keep in mind that i dont want to ruin car warrenty.
