@splfanatic I live in E 11..One of my friend is using 16d with 3001spl and a capacitor..he lives in i8/3..Anytime u can listen to his system..
I previously had a santro and was using capacitor it can easily fit in the Dig or anywhere..
Cpacitor shares the load with alternator,battery..Provides power where is required..Big setup requires capacitor cause local manufacturer car alternator sucks.. Reduce flicking of head light,provide clean power to amplifer
@da_realplayer yaar i want a capacitor..but u asking too much.. mujhe POWER ACOUSTIC ka capacitor 5.5k ka mil raha hai 4 months used.. ab aap apni final demand bata do..agar mujhe aap ki demand samjh aae to main aap se purchase kar loon ga..i need urgent.. contact FARRUKH : 03002146648
@splfanatic Next week tuk raha tu ap ka hoi if ur intrested
@farukh First you cant compare power acoustic with Soundstream... Power acoustic can be compare with lanzar,Ma audio.. Soundstream can be compared with Rockfordfosgate,Jbl etc..
See the price difference gap between power acoustic and soundstream products you will get the idea of price....
First thing , big three improves electrical system in your car , its not the fault of alternator ( output remains same from alternator while only FLOW OF CHARGES is improved )
2nd thing : Use of Capacitor fails if voltage remains below 11v during playing bass music , dropping voltage below 11v , even amp lost is power and completely starts to distort , if capacitors shows voltage below 11v it , indicates bad charged mostly it happens drop below 11v , but 10v its comes to more straight failed charged and useless with your system
keep in you mind , putting 2.0f capcitor , you will need to put very big alternator to charge capacitor rapidly , during Power consumption due to bass by Amplfieir
@geforce I agree but adding caps improves sounds big time...Providing the charge it has store where it is required to the amplifier.. My capacitor show around 13.7-14.1V while listining,have two dry batteries
@da_realplaya yaar woh sub theek hai..mujhe original 1400rms power produce karni hai..m using Crossfire Woofer XT212 1400rms..jabhi aap se yeh sub poocha aur aap yeh kaise keh sakte ho kay soundstream ko rockford se compare karo.. i think crossfire is heavier then rockford and soundstreams...
Power amp nay produce karni hay if proper alterntor,battery wiring.Capacitor only helps in storing charge where is required,maintian power,Provide charge where drops.I am using this capacitor this JL 13.5W7,Fusion Nv-am25001 Amplifier,120amp batteries SETUP.Work fine 13.7-14.1v show kata hay works abosultey fine. And regarding crossfire fire compared to rockfordFosgate,Soundstream you will find the answer on web.
@Geforce Soundstream over Crossfire anyday..Crossfire products cannot be compared to soundstream..As further Rockford Fosgate rules over soundstream.That is wat i was trying to explain
