my honda civic 2007 is showing engin check light and air bags light. i scanned it and the scanner is show po 135 error. what could be wrong here??
is your vehicle JDM Model or pakistani model?
it is possible that the ecu is changed with JDM one which has oxygen sensor in the exaust but 2007 honda civic pk dont uses the oxygen sensor and relies on carbon quantity adjuster.
maybe its changed. what should i do??
stick with it or redo the wiring harness and install a oxygen sensor for your self and get rid of this problem..
You need to change your oxygen sensor and please dont put kabuli sensor in your car.
and what about air bag light??
what about air bag lights??
had to scan it too for DTC output only then we can help you here
