1: Replace the wrong ECU. Sell your P08 here and get a P2J. Even a P2J auto is fine.
2: Get rid of these good for nothing plug wires, get stock ones from Bilal Gunj. Replace all plugs.
Do you have 2 wire IACV on the back of your IM, or a 3 wire one at the bottom of TB? Try to clean and lubricate it. Follow the proper procedure. (Just google for it, or download workshop manual). Do check for any air leaks. And your engine stabilize to what RPMS when you turn on the AC?
Why, infact 'how' for that matter, would ECU stop an injector if plug is not firing? Have you checked your injectors? Does this happen at any certain RPMS range? Do you feel hesitation or surge in throttle response at times?
