Dear Friends..
Sharing my experience of Qingqi Trail 150cc...
Bike: Qingqi DP 150cc
Model : 2014
Category: Dual Purpose Trail
Engine: 150cc Single Cylinder 4 Stoke Air Cooled
Tank: 10 Lit
Battery: 12V 7 AH
Seat Capacity: 2 Person
Starting System: Self & Kick
Max Speed = 120km
Break Front/Back = Drum
Best Average Till Now = 38km/Lit
First Run of 380km from LAHORE TO ISLAMABAD
1st Run
Got Average of 29km/Lit, Very Much Comfortable in long ride no pain in shoulders & back, Pick is not good which is a big? Mark for DP Trail Category ? GS 150 Engine is far better in pick & Torque then this Engine.
1st Tuning
Tuning & other thing which need to recheck (carburetor Cleaning & Setting, Taped Adjustment, Oil Pump Checking, Gear Ring Checking, Front Shock Oil Change & Setting, Break Leather Checking & Complete body Inspection & Tight up all the nuts & bolts.
2nd Long Run of 850 km Kashmir
Got 38km/lit, Break Performance Increased, Smooth Shocks & better pick then before No Trouble on long run even continue ride of 8hr. Yes Missing on Peak heights which can be reduce in low gears but still annoying it will break your motion & speed. No problem in MUD, WATER (Event Half Engine in water) & ROCKS. Good Grip & breaking as well, shocks are very much comfortable on rocks.
3rd Long Run of 350 km Banjosa/Toli peer
Got 34km/lit, Front Brake need service nut got slip, Smooth Shocks, & Missing @ height Toi Peer ... Remove the air filter to chk but same performance so need expert advice...
Rest non stop all the way...
1600 km on the Clock ...till now.
Engine Demonstration & Maintenance (Post # 47-52)
Parts Replacement / Availability
After buying any brand which is unknown to market parts are as important as bike itself. Here is the list of the parts which I easily find in case of emergency Happy to see that all parts are easily available.
Rear Brake Shoe = CG 125
Clutch Cable = CG 125
Front Brake Cable = CG 125
Chain = CG 125
Electric Coil = CD 70
CDI Unit = Cg 125 (Grips need to Replaced if u need to put Orginal one of honda but if u need to put the same then u can get it Chinese brand)
Carburetor = Honda Deluxe 125.
Front back Lights Bulb = Honda 125
4rth Long Tour
(Before Another long tour )
Rear Brake Shoe Changed = CG 125 Best Quality Used (Post # 83)
Clutch Cable Changed = CG 125
TOP BOX (Post # 84-85)
Bought Water/Heat proof Bag
Capacity 16lit
Good thing it comes with Plastic Containers which is inside of the box which sustain its shape & provide safety for inside things.
Overall Review: Satisfied with the performance & Handling, Light weight front make it much comfortable on sharp turns, and good in grip.
