May 2008
1 / 122
May 2008
Sep 2020
2day i got my engine flushed using wurth engine flush & cleaner!my car has total been driven 36.5k n the oil used was mobil1 5w-50 drove it 8500km!
bought the engine flush/cleaner poured it into the oil,started the car n let the car idling for 15mins n then switched off the engine and drained the oil n this is what came out!this stuff actually works all the carbon deposits,sludge etc etc all came out n this is the result of the oil drained! :stuck_out_tongue:
i was using mobil1 first n now ive poured in liqui moly 5w-40 fully synthetic!
  • created
    May '08
  • last reply
    Sep '20
  • 121
    replies
  • 37.0k
    views
  • 34
    users
  • 9
    likes
  • 2
    links
Frequent Posters
There are 121 replies with an estimated read time of 18 minutes.
the whole bottle which consists of 400ml is enuff 2 treat 3-6lit of oil!just pour the bottle in n let the car idle it causes no damage to oil seals or nything n neither does the car begin giving off smoke frm the exhaust!
advantage yeh hai keh ...
[highlight]Cleans the inside of your engine oil circuit by removing carbon, sludge and varnish residues
Keeps new engine oil cleaner for longer
Neutralises harmful engine acids, prolonging engine life
Increases engine performance
Improves fuel consumption
Reduces exhaust emissions
btw its compatible with all mineral and synthetic based engine oils
here are more advantages:
An agent to thin old oil, breaking down sludge and particle build up to ensure maximum drainage.
A detergent to clean away residue and unclog oil ways, galleries and neutralise crankcase acids.
A lubricant, (organic molybolan compound) to protect the engine while the solvents and detergents are cleaning.
Newly developed concentrated agent for dirty engines or old oil
Your advantages:
New oil remains effective and clean longer.
Loosens dirt and sludge deposits inside the engine.
Dirt is effectively removed when used oil is drained
Contains surfactants with a strong detergent action
Your advantage:
Cleans and flushes the entire engine oil circuit
Uses / Areas of Use:
If black sludge is suspected.
If hydraulic tappets chatter.
If the oil change is overdue.
In the event of a loss of compression from sticking piston rings.
For all mineral and synthetic based engine oils.[/highlight]
750rs ka hai!
well tumari mehran kitni chal chuki hai?n wats the engine condition like?n which oil u using?mineral,semi or fully synthetic n since when?
Thanks for price well meri mehran around 130K chal chuki hy per recently engine overhaulin karwaya tha yani engine karwany ky baad 8K chali hogi. Main Mineral oil use kar raha hon Total ka CNG wala aur jab sy engine karwaya hy us waqt sy pehly Shell ka red CNG use karta tha.
sir gee wat the name of the product and which company has launched it , is it a product of well know comp or an impored stuff
also tell me i m using havoline formula since i bought the kabli engine and its driven nearly 30k
its a well known firm called WURTH!
@suzukimehran
haan u can use it in ur car as it wont cause any damage,i mean keh it wont open up places(leaks) tht were clogged with mineral deposits etc etc...u can use it in ur car it wont harm or do any damage it will simply flush the system out!
but i wud recommend u using fully synthetic oils as they are known not 2 produce any sludge!
@azcol
haan u can even use it in ur engine...my car is even driven around 36k!but i wudnt recommend this product in older engines which hav been using mineral oil since a very very long time like 95 onward models such as civics,corollas etc!either use this product if ur engines r well maintained or if uve been an old user of synthetic oils n ur car has been used 2 syntheic since the first start!
thnx for the information aamir .... bt i hv vitz 2003 ... n i use mineral oil since i bought tht car in 2005 .... nw m planning to switch to synthetics oil .... cn i use tht engine cleaner ? its driven arnd 60k
@ahmed
haan u can switch frm mineral to synthetic...infact synthetic is better it doesnt form sludge the way minerals do!first flush ur engine let the mineral sludge n deposits get out n den pour in synthetic...synthetics hav additives in em so as u pour it will start cleaning the moment it enters hence it will gradually scrub off the crap tht minerals left behind n during each oil change woh nikalta rahayga!
@aamirq
bro would u recommend it for a new car whose first oil change is due. i think it might help as i'll put in synthetic oil so the cleaner should clear all the mineral oil from the engine. right?
@aamirq
whats the differnece b/w mineral and synthetic oil?
how do i check whether its is mineral or synthetic?
I have cultus 2002 using shell cng oil,changed oil in March(dont remember the Kms)....till now its 98k driven...should i go for it??
@riaz
yeh bro cz den ur synthetic oil wud hav 2 work less harder 2 work in cleanin out the system,thus meaning ur synthetic oil wud b cleaner for longer tht wud result in extended oil change intervals!
@aamir
i own coure its 47k driven nd i m using caltex havoline (black clr), i usually change the oil at 3k km's.Suggest me can i use this product in my car although i have to wait until my next oil change coz i changed the oil few dayz back.nd plz tell me the name of this product nd its better if u post the pics nd after how much km's z it necessary to clean the engine with this cleaner?
ADVERTISEMENT
@pakisnake
bro the yellow cng is mineral...and in mineral oils u have 2b really on time 2 make sure oil has been changed coz once it passes its life the oil breaks down thus forming sludge...
yar bro usually oils keh backside par likhawa hota hai in the details of the oil if its mineral,semi or fully synthetic!
n yeh 1 thing for all of u out there reading this THIS IS TOTALLY A MYTH THT ONCE U SHIFT 2 FULLY SYNTHETIC U CANT SHIFT BACK 2 SEMI OR MINERAL!U CAN!!!!this myth was originally generated when fully synthetics were newly launched n they had issues of having the rong ratios of detergents in em!with time they sorted this issue out n made it perfect so now its no problem shiftin to n fro!
haan i wud recommend gng for it as ur ride aint tht old!ulta flushing it will refresh ur engine it will clean all internals tht hav been flooded with sludge...coz eventually engine sludge thus cause damage doesnt matter bmw ho ya mehran coz sludge is deadly for all engines thts y a few oils such as mobil1,liqui moly,zic xq etc hav been porsche,bmw,MB,vw approved coz it passes their tests n r healthy for the engine knowing the engine oil wont give up easily n it has the power 2 protect n clean while lubricating well!
@shazi
good 2 hear tht u change engine oil @ 3k...meaning tumara engine waisay hee saaf hoga indar seh!haan use it in ur next oil change!yar u can use it every alternate oil change(this is for ppl who go for longer drain intervals such as 10-15k) but in ur case i say u flush it once n den use it after 10k! for eg if u flush ur engine 2day at 47k den ur next oil change is due at 50k...remain changing oil witout flushing but once uve crossed the 10,000km mark of changing oil witout flushing then flush!coz if u flush too often its gng 2 start damaging the internals it will start 2 do more harm than good!coz as u know too much or too lil of nything is a bad thing!
@aamirq
Thanx 4 information...
one more Question: which oil should I go for in the next oil change...bcoz my daily route is Super highway(New Subzi Mandi)...
@pakisnake
bro tumari daily running kitni hai?i mean kitni km total?n tel me how much u willing 2 spend on oil ill guide u accordingly coz oil 3250rs tak ka b ata hai,such as the 1 which i use!so tell me ur budget of engine oil n ill suggest accordingly!
