Need Your suggestions guys.
This Toyota engine keeps troubling me.
- It keep breaking CV joint.
- Heat comes inside on long run.
- Fuel consumption.
- The first gear doesn't seem easy.
I went to mechanic, he diagnosed that engine is not mounted properly and axles are not through properly, forming slight angle from the transmission side, which results in breaking CV joints and axle. For which he said If the engine mount is going to be corrected then it need more modification, would result in cutting chassis.
Secondly, He said the engine is big enough for this engine bay. not suitable for long run.
So now, I am planning to get back to its original engine GA14DE.
What you guys suggest? Should I go for this or something else ?
Also mention costing for GA14DE and for other engine that you'll suggest !
Suggestions and advice are welcomed...
