well not just incase ,,,,,,,,I want to restore it back other then engine ,,,,,,,if possible for you then find detail about that stuff ,,,,,,,,, I will start working on my D21 in a weak time ,,,,,,,,,engine I will upgrade and rest every thing must be restore back ,,,,,,,,,this D21 has torsion rod front suspension and leave spring at back ,,,,,,,,,but I have google some pic of D21 with spring suspension at front ,,,,,,,,, you can see my D21 is quite lower from front end and high at back ,,,,,,,,,,from back it can be easily lowered ,,,,,,,,,front can also be adjusted from torsion rod,,,,,,,,, but I don’t think I can get the desired height with that ,,,,,,,I want to make it level,,,,,,,, I need to dig out that ,,,,,,,, car is not yet in my hands ,,,,,, its parked at some other place ,,,,,,,,, I will get it in few days then will check all that in detail ,,,,,,,,,,,
