Nov 2012
1 / 6
Nov 2012
Nov 2012
I have to attest my degree from UAE Embassy. As I am currently in Lahore, so what would be the quickest way to do this??
I know there is an agency named as SASHA in Islamabad but for that I would have to go there. Anyway I could do it from Lahore and if yes then how much time/cost?
Thanx for ur help
  • created
    Nov '12
  • last reply
    Nov '12
  • 5
    replies
  • 18.9k
    views
  • 1
    user
  • 2
    likes
You can courier your degrees to SASHA, they will charge you Rs. 5400 per document to get that attested from UAE Embassy. If you go to SASHA personally, than the charges will be around 4200. Before sending it to SASHA, you must make sure that your degree has been attested from HEC (not more than 6 months old), else they will ask you to get it attested again from HEC.
To get degree attested from UAE embassy, you need to get it attested from HEC and ministry of foreign affairs first.
I know this guy he got my friends degree attested from Ministry, HEC and UAE embassy, one window operation :wink:
His number is 03334526565 name is Noman.
Hope it helps.
AllahHafiz
@SGHS...Thanx for sharing this info.
Can you confirm this guy is legit? Because I fear that here people use fake stamps too. So, what's the reputation of this guy
Thanks
When it comes to original documents, its better to do everything on your own instead of trusting someone else. It will be a hassle but it better to be safe then to regret later if something goes wrong.
