Does anyone know how to reprogram passo boon 2007 keyless-go entry smart key??I want to buy a second hand keyless-go entry smart key to reprogram for my carMy keyless-go entry smart key is same as the picture I uploading
Some of these transponders are not re-programmable which means used key is not a good idea. Do you want to program only the FOB or FOB plus the Key.
Have you gone through this thread?
FOB only , for keyless start the carI have check his post but he got said he only can program the FOB which show the picture on his thread
Did you try the negative terminal removal method given on internet? Did it work?
It does not work
it also didn't worked for me. Can anyone help?
I'm pretty sure there are tools out there that can either program a new FOB for keyless entry or make a clone of existing FOB. The only problem i see is that there are too many of them. One tool works for a few cars and doesn't work for others. Your best bet is to go out and check the market.
If you can get hold a Toyota Techstream software then keys can be easily programmed provided you have a virgin key available.
