Error Code: P0171 System too Lean, Bank 1
Possible Causes:
- Intake/exhaust leak.
- Manifold absolute pressure (MAP) sensor).
- Mass air flow (MAF) sensor.
- Fuel pressure/pump.
- Injector(s).
- Evaporation emission (EVAP) canister purge valve.
Heated oxygen sensor (HO2S).
Possible Solutions:
- Mostly, simply cleaning the Mass air flow (MAF) sensor does the trick. It's best to take it off and spray it with electronics cleaner or brake cleaner. Inspect all vacuum and PCV hoses, replace if necessary.
- Check for a dirty fuel filter and proper fuel pressure.
The intake manifold leakage can easily be checked by starting the engine at idle speed and by pouring a plain water around all the intake manifold with an empty bottle of coca cola. By doing so carefully listen to the sound and the idle speed. If any sound like Shhoo Shhoo and the change in idle speed is observed, locate the point and repair it as needed.
Good Luck.
