Dear All,
This is to advertise that I have finally made up my mind to sale my competition level branded Mono Block Oxygen Audio Air2proM2.KW (2000 RMS @ 2 Ohm), Made in France (Has No comparison but far better than Solid Audio F-1600D / F-2500D, MUST read its Overview & Specifications part) almost in brand new condition along with its box packing & accessories etc. just for Rs.30,000/ (If required I am also ready to courier it to anywhere in Pakistan).
WebLink:
http://www.electronicsbonanza.com/comersus/store/comersus_viewItem.asp?idProduct=15267&sku=Oxygen-Audio
Overview of O2 Oxygen Audio:
O2 (Oxygen Audio) is known by car audio competition experts to be the best value and best quality brand around for hard hitting subs and speakers. They originally started in Europe and now they released products in the US as well. They have been winning car audio competitions every time they try. The same model Air2ProM2.KW over here for sale has been used in many of these winning show vehicles competing in sound quality level (SQL) competitions and Sound Pressure Level (SPL) competitions around the world.
For all of you looking at this product and are familiar with the air series from Oxygen Audio, you already know that these amps will have better sound quality and hit extremely harder than anything else with similar ratings.
If interested, please contact 0300-9272348.
I personally guarantee that Oxygen Audio Air2ProM2.KW will definitely fulfill your current requirement as well as your future needs. This will deliver the extreme power (4000 Watts & 2000 RMS) along with the super fine sound quality at all output levels. Believe me it really delivers the best value and best quality sound if compared to other brand ones famous around for hard hitting subs.
IN SHORT:
THIS IS JUST A ONE TIME/LIFE TIME BUY & YOU WON?T NEED TO CHANGE / UPGRADE THIS EVER. In short I would say ??Buying Once a quality product is always better than changing low budget stuff again & again??
Specification Oxygen Air2proM2.KW:
Make: Oxygen Audio (Made in France)
Model: O2 Oxygen Audio AIR2 PROM2.0KW
WebLink:
RMS Power (CEA Rated) at 13.5V :
At least, -- 1,000 RMS x 1 Channel @ 4Ω Load ( Rated at 13.5V )
At least, -- 2,000 RMS x 1 Channel @ 2Ω Load ( Rated at 13.5V )
Max Power: 4,000 Watts (Confirmed)
- O2 Oxygen Audio AIR2 PROM2.0KW
Efficiency: > 90%
Distortion Rate: < 0.05%
Dimensions: 20.8" x 10" x 2.40"
Digital amp w/ limited band: 10 - 250Hz (-3dB)
Cinch inputs: Stereophonic
Double speaker output: Monophonic
Load Impedance: 2 ohms min. i.e. 2 x 4 ohms in parallel
Low Pass filter 24 dB/oct: 50 - 250Hz
Subsonic filter 24 dB/oct: 20 - 50Hz
Bass Boost Circuit 0~24dB (Variable)
Infrasonic filter 15/25Hz (24dB/oct)
Phase setting: 0 degrees to 180 degrees
Phase setting (inversion of LS polarity): 180 degrees to 360 digress
Sensitivity: 100mV to 8 V
Signal/ sound ratio: 90dB
Line in RCA (Gold Plated)
Line out RCA (Gold Plated)
Gold Plated Power & Speaker Terminals
Operating voltage 13.5V (11V ~ 16V allowable)
Pictures:
Original Pictures are uploaded.
Demand:
I am asking for this remarkable/extraordinary Mono Block Amplifier, just Rs.30,000/
