Its generally said that the best suited speed for max. fuel efficiency would be, when the speedometer needle is purely vertical on the speedometer (be it at 100, 120, etc.), however then, the max. speed limit is 120 kmph and it can't be exceeded.
So you can drive at 120 kmph, or the speed when needle is purely vertical on the speedometer, whichever is lower.
Do not rush, or drive fast or in a hurry, or without sufficient stops, etc. Its said that haste makes waste.
