I bought this scanner and I can't connect it with any android app I downloaded from the playstore.Please guide me which app and code works with Vitz 2002 . Thanks
If the OBDII device connects well with your car and shows that it's ON, it should connect by Bluetooth with any OBDII android app, from PlayStore.
Its not.Thats the purpose of making this thread.
It connects with OBD2 Bluetooth but cant connect to ECU.
You got the ECU working?What app/device are you using?
No i didnt find tht connector and Toyota software...
So now what?Do i buy the device from local mistri lol or what.Any ideas?
Get the ECU connection checked.
It will not. It requires a modified OBD standard called JOBD .
Any idea where can i find it?
Pretty expensive compared to normal OBD adapter. Search AliExpress
Try connecting hobdrive with your same device. It has preset profiles. Go in Toyota you'll find yaris in it.
Ok thanks
Wth which generation of vitz it connects ?
Mine doesnt conecct.Is your vitz 2002 1SZ-FE?Please inbox the torque app.Thanks
Kindly give your feedback, did you find the solution??
