If any one needs local made nitrous kit.... so pls kindly contact me .... any WET nitrous kit available in new in market minimum in 650 - 750 US$ excluding all taxes.. shiping charges.. import duty..... n etc.....C ZEX ORIGINAL WEBPAGE
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=CTGY&Store_Code=ZX&Category_Code=KitsFuelWet
but i can supply u brand new local made "WET nitrous kit" in just 234 US$ & "DRY Nitrous Kit" in Rs. 196 US$.... Fixed
N THIS IS VERY MUCH CHEAP... C THE PRICE DIFFERENCE...
my email iD Is : umairint@live.com
THIS OFFER IS VALID FOR FIXED TIME PERIOD... I CAN INCREASE THE PRICE WHNEVR I WANT...
C THE DIFFERENCE IN PRICE..
ZEX WET NITROUS SYSTEM COST MINIMUM=650 US$ not the C.N.F Price ....Approx Rs.52000 Without import duty.. taxes... n charges...
Include import duty... taxes... shipment charges... n others... thn u can campare the price difference...
My local made nitrous kit is just for 234 US$ for limited time period... means only Rs.18,700 & ZEX is approx Rs.60,000
c the difference.... ZEX is more thn 300 times expensive....
I Mentioned Some Questions with thier Answers Below:
Q: Can I simply bolt a N20 kit onto my stock engine?
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"A: Yes, There are N20 systems for virtually any stock engine application. The key is to choose the correct kit for a given application; i.e., 4 cyl. engines normally allow an extra 40-60 HP, 6 cyl. engines usually work great between 75-100 extra HP, small block V8's (302/350/400cid) can typically accept up to 140 extra HP, and big block V8's (427/454) might accept from 125-200 extra HP. These suggested ranges provide maximum reliability from most stock engines using cast pistons and cast crank with few or no engine modifications.
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: How long can I hold the nitrous button down?
A: It is possible to hold the button down until the bottle is empty. However you will be lucky to find enough road.......
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: Is nitrous oxide flammable?
A: No. Nitrous oxide by itself is non-flammable. However, the oxygen present in nitrous oxide causes combustion of fuel to take place more rapidly.
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: Where can I get my bottle refilled?
A: There are many performance shops that can refill your nitrous bottle generally for around Rs.1400- 1800. All Nitrous Oxide certified distributors can refill your bottle. Or in the Karachi I Have Link of Distributor of Medical Gases who will rent you a big bottle to fill your smaller ones from, and collect and deliver refilled ones too! n its cost max 900 rupees ur per cylinder refill... Many welding and engineering shops can supply too. or if u hv link in hospitals.. so u can get for free... lolzzz
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: Is there any performance increase in using medical grade nitrous oxide?
A: None! All the same.
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: Are there any benefits to chilling the nitrous bottle?
A: No. Chilling the bottle lowers the pressure dramatically and will also lower the flow rate of the nitrous causing a fuel rich condition and reducing power. On cold evenings you might run on the rich side. For optimal running conditions, keep bottle pressure at approximately 800-900 psi.
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: Should I modify my fuel system to use nitrous oxide?
A: Most stock fuel pumps will work adequately for smaller nitrous applications. It is important to check to see if your pump can flow enough fuel to your existing fuel system (whether carburetor or fuel injected), as well as being able to supply the additional fuel required by the nitrous kit under full throttle conditions. It may be a good idea to dedicate a separate fuel pump to the nitrous kit.
spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"spanTimes New Roman"; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA;"Q: What are the advantages of using nitrous compared to other performance options?
A: The cost of many other performance options can put you in the poorhouse. Dollar for dollar, you can't buy more performance with less money than nitrous. With a nitrous system, performance and reliability can be had for a much more reasonable price while retaining the advantages of a stock engine during normal driving. And, nitrous offers tremendous gains in torque without having to rev the engine to excessive rpm's. These factors help your engine last longer than many other methods of boosting horsepower.
