Yes ga15de can be rebuilt. And a good overhaul will cost you around 80-90k including parts, labour, lubes & machining. However if you tend to buy a engine head assembly that is around 90-100k a good Japanese assembly. Overhauled engine can pull around 150-200k or even more. Kabli assembly can pull 50-60k and then the oil ring or valve seals will require maintenance & the used parts since have a life so these engines require part replacement to pull good miles on it.
Engine swap with QG15 is perfect for it but that's gonna cost you around 170-180ish which is alot considering overhaul and head assembly swap.
Rest you can plan a visit, we are well aware of Nissan systems & it's electronics.
