Salaam
Up for sale are Narada 100 ampere/hour Acme-G series Dry gel batteries.
Narada is one of the top notch battery manufacturer and their batteries are widely used for UPS and solar power systems and are known for their quality product. We have been directly importing these batteries mainly from USA .These batteries are in excellent condition. The AcmeG range front access gel batteries are designed based on the Acme series. Using the polymer gel electrolyte with real front access structure. The state of the art internal and external design ensures AcmeG the high reliability and makes the installations quite simple and safe when placed on a standard relay rack tray or in a closed cabinet. The design float life is 12 years at 20℃(68℉). These batteries can be used for UPS, Solar charging bank, and wind energy or for any other charge storage purpose. These are maintenance free lead acid batteries so they don't require extra care like liquid batteries. These batteries are gel series and they are highly reliable as compared to liquid or AGM batteries and provide an expected life of 8-12 years.
Main applications
- Telecom standby and cyclical applications
- UPS
- Power plant and power transfer system
- Solar energy system
- Emergency lighting system
Following are the specification of these batteries
Condition: mint condition
Item Description: Narada 100 ampere/hour Acme-G series Dry gel batteries.
Nominal Voltage: 12V
Capacity: 100Ampere/hour
Dimensions: 287 x 390 x 105mm
Weight: 33kg
Max charging Current : 25 A
Terminals: Terminal connector to screw M6/M8
Mode of Delivery : delivery to anywhere in Pakistan on buyer?s expense.
These batteries can be load tested before you purchase them in order to insure the proper working condition .We deliver our batteries to any place in Pakistan .
Here at Hitech powers ,we are dealing in wide range of Dry Gel and AGM series Batteries and Solar panels also. If you need any other information about these batteries then please feel free to contact us.
0336-8214800
Abdul Samad
