Assalamulaikum all. Here, I'll be sharing a DIY that I did today/yesterday.
The car in question is a 2009 Daihatsu Mira L285 which belongs to my brother. Although it had excellent visibility with the halogen bulbs, but my brother always wanted HIDs in it and having tried the motorized H4 type HIDs in it with pathetic results, we decided to go the projector retrofit route.
These are Morimoto H1 6.0 Bi-Xenon Projectors without shrouds.
The bulbs used are CNLight 4300k H1s, bought from a fellow Pakwheeler.
The car before the surgery
During the surgery
The lights were then left in the oven for a few minutes and then I used flathead screwdrivers to pry them open. Once they were open, I cleaned them and installed the projectors with my custom shrouds. The holder that comes with the projectors is made in a way that the projector sits tilted to one side. All it needs is a little filing and you can turn the projector straight.
Once the projectors were installed, I test fitted the lights onto the car to see weather the cutoff meets the previously marked spots on the gate or not.
You'll see that the cutoff is alot lower than the marked spots. The headlights have motorized height adjusters that are controlled from the inside of the car, which were adjusted to the lowest when the pic was taken.
Optimus Prime, is that you?
The headlamps sealed and fitted back onto the car.
The bumper back in place
Night time shots
The epic cutoff line that comes with Morimoto's projectors
The high beam
Thats all folks!
