Another Russian creation. The MIL 26 Halo is the biggest helicopter in the world.
The Mi-26 was designed for military and civil use and intended to be able to lift more than any previous helicopter. The first Mi-26 flew on December 14, 1977 and the first entered service in the Soviet military in 1983.
The Mi-26 is powered by two Lotarev D-136 turboshaft engines, providing 8,550 kW (11,400 SHP) each. It is fitted with an eight-blade main rotor, with the blades made from fiberglass with steel spar cores and fitted with titanium on the leading edges. The rotor blades have an electrical de-icing system, and the rotor hub is made of titanium.
It can lift more than 20 tonnes.
MOD EDIT - Moved to aircraft section
