Aoa.
I have a mazda rx8 2jz-ge swapped. the car is with a clean swap and electrical wiring was also done professionally from a well reputed electrician.
I'm having trouble with the car's mileage, recently the car is delivering a mileage of 4-6 kmpl with a light foot.
Everything else is okay, no problems with power or anything, engine is water dropping with optimal compression.
The car has a MAF sensor recently serviced and I have also installed an aftermarket FPR to ensure the fules regulation.
I was advised to install the oxygen sensor back that it will help in mileage since it was taken out while the exhaust was straight piped...
Would be grateful and open to suggestions
Regards,
