Jan 2015
1 / 55
Jan 2015
Nov 2024
Hi,
I am non believer of Oil Additves. But i tried Liquimoly Ceratec in Prius 2007 and noticed following improvements.
Engine becomes very very smooth.
Increased Mileage +2 Km/Litre
Engine noise is reduced alot under even extreme load.
Acceleration is better by atleast 10%
Please also post your reviews if you have used this product.
  • created
    Jan '15
  • last reply
    Nov '24
  • 54
    replies
  • 32.3k
    views
  • 29
    users
  • 14
    likes
Frequent Posters
There are 54 replies with an estimated read time of 5 minutes.
I bought it from Havoline Express PIA Road lahore for Rs.2700.
yeh iv used it before kaafi martaba! but i wouldnt recommend using it if a person uses high end expensive oils such as mobil1 etc...since u have to add this into the oil! all the advantages are written that it does this and that and that but what does it do with the oil? iv noticed one thing that the color of the oil on the dipstick changes after u add ceratec!
I don't think it matters if your car is w hybrid or not. The engine is the same thing. Engine control is different
available here at 2500rs.. i am thinking to add it ths time! But need some recommendations b4 adding it
Used it in Mitsu EK, civic 02, city 09 AT, Platz 01. on all the cars results have been good as engine noise was reduced significantly. but how good only time can tell. once the engine covers 50k km or so.
what about gear oil additive of liqui moly? what is da review and price of it?
It can be used both in petrol and diesel engines no restriction its given on liqui moly website suitable for petrol and diesel engines and mixes with all commercially available oils.. but you are right it may mess-up the viscosity somewhat which hybrids are very picky about.
i am using it in my Diesel Yanmar Generator with Mobil 1 15W-40 mineral oil, though it has not made a huge difference, it has reduced noise and it runs pretty smooth and doesnt even flinch when all the load is turned on like a bit before. and it made a the little bit of smoke it had disappear. i had to use two bottles of it as the oil capacity of the generator is 8litres and it definitely changed the colour of the oil.
but ceratec gets flushed along with the oil if u use an engine flush to flush engine oil out of the engine! dont expect ceratec to remain stuck to all the metallic parts if u flush the engine using some good quality engine flush such as liqui moly motor clean etc etc...
ADVERTISEMENT
I am very happy with this product, i think 50000km is a bit too long so i will be pouring it again after 25k.
Im also about to clock my current engine oil, planning to change it after 3k km, i got a corolla axio, thinking of getting liqui moly engine oil this, should i also get this ceratec? Expert advice needed.
I had personally used it in my hilux surf 1kd-ftv engine and the results are amazing. Now the engine is less noisy and the sound of the engine is completely changed. I am using it with LM 5W-40. Synth oil. The time interval of oil change is between 9500- 12000 kms. Really amazing product.
