Without hasport it would be abit difficult... We recently swapped a k24 type s in a ek with hasport mounts..
However I've a large chain of engine providers here in Islamabad with clean 200psi compression or greater type engines.. Five speed would be easy dig for a swap.
You can use its own back mount of five spd gear and timing mount would also be used custom. So making custom would be abit hard and mostly you don't get that skilled mechanics or fabricators.
However in that case hasport mounts would be better for you but get it professionally checked by someone who's done such swaps... Like if you come to me I'll make complete feasibility of fittings and the whole plan or home work would be done.. If you just attempt it with low. Budget and then things get tough so it would be hard to keep up with the project.
