Bought side skirts for my corolla and as i had a day off so did a Diy on my rolla. Hope it helps .
now i dont know much about how post the pics along with text so am just describing everything over here, so you can refer the pics after your done with the text.
Step no:1 First remove the front two mud guards and remove all screws and plastic rivets that are holding up the factory skirt.
Step no:2 In the first pic ive shown the plastic rivets located at the bottom holding up the side skirts.Now removing them was really exhausting and tricky.To remove them first free the flexible plastic portion of its side locks by freeing one lock at a time then pull the sides of the plastic while holding them firmly and with the right amount of force gradually.. dont give it the brute force pull otherwise youll get the flexible plastic detached but the rivet wont as it would slip through it, so be careful about that and just give the right amount of force and hold it gud from sides when your pulling it with the right amount of force. This way remove all the rivets carefully without breaking them.
Step no:3 After removing the rivets remove the screws holding up the skirt two located in the front while one at the back(shown in pic)
Step no:4 After removing the three screws its time to detach the side skirt for that simply hold the back end of the side skirt and pull it,it will get detached.
Step no:5 After removing factory side skirt remove the plastic holders from it and place them on the new side skirt.
Step no:5 After placing all the necessary holders its time to install your new side skirt which will eventually turn out to be a piece of cake after all the procedure youve gone through...attaching my pics of the car when i finished installing m9..
