Hey, buddy. Can you help me activate the cruise control also? I did the conection with main cincuit (dashboard) and the first green light “main circuit” appears, but when I try to activate the second stage, I can't. I thinking that left connect a wire with the PCM. The connection that I did was in main circuit with position 23 - yellow wire and position 7 - little green. ( the green light at main circuit in main circuit are working but the second green light at main cuircuit doesn't working yet.
My Civic is 2014/2015 and I checked that the connections of breaks are going to PCM. The pin 4 are connected in PCM in 25 pin and the 3 are connected at fuse box under dash, and after, are going to 43 in PCM
