Honda Civic 2011 Manual Oriel's hydraulic steering started leaking. Just 3-4 drops per day.But people have suggested to opt for EPS. Where can I get the work done from Rawalpindi/Islamabad? And approximately how much would it cost?
Get the power steering pump rebuilt. You can get the seals from dealership.
Dear its a known and on going issue with all Reborns. I dont think there are any healthy hydraulic pumps left in the kabli market. its better to switch to EPS. will improve your car's milage as well.
How is a leaking hydraulic pump a known issue? They all eventually leak, just replace the seals.
it usually not the pump instead the steering rod seals leak in reborn and only seal replacement doesnt do the trick.
i had to get it replaced atleast 3 times in 2 years.
Is a new steering rack more expensive than an EPS conversion?
i dont think there is any new steering rack available in the market.
it would have to be ordered in then, as probably no one would buy new.
