I need some help regarding Honda Civic Orial 2018, while changing the air filter, I had to remove the wire clip of Mass Air Flow Sensor, after replacement, I forgot to insert the clip of Mass Air Flow Sensor back. I started the vehicle, it refused to turn on and threw all sorts of errors on display. Immediately realizing the mistake, I connected the mass air flow sensor but error code remained intact.
I brought my EML 327, tried to connect with my phone but it failed, maybe this was my first time, I need to find out about correct protocol. Took off the negative lead of car battery to reset the codes, after 2 minutes inserted it back, codes went away but it now shows that stability control is off as two lights now lit on my display related to stability control. I tried to manually turn it on but its not responding. Kindly comment and help me resolve the issue.
