I have a civic vti which is suffering from over heating. The needle goes up to the redline and stays there if i drive normally but when I decelerate or go down hill the needle come back down( eg when going down hill in the salt range the needle comes back to normal. The engine never had a head job or gasket change. I changed the radiator to double nali desi one some 5 years ago.
I am getting oil in the radiator as well, burning a plug of one cylinder and oil reduction but the car is still half self start.
I am going to get some things done this weekend from a mechanic in Faisalabad EId Gah road as he always had figured out problems of my Honda but in a desi way. Had a bad experience with Honda pit stop the couldn't even fit a side view mirror properly . Would have got it done from Lahore but the car cant travel that far now L
- Head gasket replacement
- A ring and valve seals job depending upon the damage done to the engine
- Water body replacement
- New timing belt
- New radiator
- New silencer as the old one may have clogged with oil.
Any suggestions and information about any other good mechanics will be appreciated.
DAY 1 : The weather was quite ideal for spending a day at the work shop. The engine was opened up and was taken out for complete over haul.
After inspecting the cylinders the mechanic said that a simple gasket change will not do the job the block needs work to be done and needs to be taken out or the other option is get it swapped he gave me both options. I gambled with the overhaul.30- 40 k might go down the drain but I am mentally prepared for that. The block was taken to the kharadia. Came back at 3 the mechanic said he will inspect the engine in detail and tell me about the parts to be replaced by tomorrow.
DAY 2.. Went to buy the parts
bought will be assembled today by kharadia and again by mechanic tomorrow
1.Pistons
2.Rings
3.Valve set
4. Clutch Plate
5.Misc. Bearings
6.Timing belt
7.HeadGaskit
Costed me 22 k.
Total expenditure till now 22k+4000 khardia+3 for kabli piping and junkyard items=29
DAY: 3 The engine block is ready and in the Engine bay.The head will be places tomorrow. Got a new water Pump today worth 2400 that makes the total expenditure till now 29000+2400=31400
DAY: 4 The overhaul was eventually completed today. Got the double Nali DEnSO/HONDA Radiator. A set of belts. Total Spent on the radiator 5000 and belts 600 and some nuts and bolts 200=5800 ,Oil and fluids,coolants 3200, miscellaneous 2000
The total Spent on Parts 31400+5800+3200=2000=42400+8000 Mechanic Labor=50400 Rs for the engine over haul
DAY: 5 Today I got the some sounds resolved that were coming from the driver side wheel.
Got new
Disc Pads whole set , Goda Boot,steering boot,Chimta bush, Discs Facing,end repair, Ball joint repair,front brake cylinder kabli,break oil
This wheel job costed Rs 6540.
Got a new silencer worth 2200, Wheel alignment Rs 150
Total spent today 6540+2200=150= 8790
Total Spent during 5 days =50400+8790=RS 59190
1.Pistons
2.Rings
3.Valve set
4. Clutch Plate
5.Misc. Bearings
6.Timing belt
7.HeadGaskit
8.water Pump
9. Ball joint
10. 3 pump belts belts
11. Radiator
12. Pipping
13.O rings
14. Break Pads
15. SilencerOVERHAUL COMPLETED Thanks GOD
I pray that it stays this way . It's the first 5 minutes of running time that can wipe out a new cam. The other 15 minutes is just insurance. Lets see what it does in the future
