Bhai, Corolla ki to anna kar deni wali light hai. Woh City mai nahi mil sakti.
The main reason is that it had two separate reflectors with separate bulbs for low and high beams. Whereas, City has got just one reflector and one tube with two coils for high and low beam.
Secondly, you have installed HIDs in a light which is not designed for HIDs therefore the result is even worse. Yes, the car coming from the opposite side will definitely abuse you but it won't improve your visibility on the road. Either go for some very good quality HIDs which would be kinda expensive, or just switch back to the original bulbs perhaps with higher wattage.
