Mar 2017
1 / 7
Mar 2017
Mar 2017
Hello,
I have installed Philips X-treme Ultinon LED in my swift. here is the product link and result images are attached.
http://www.philips.com.my/c-p/12953BWX2/x-treme-ultinon-led-car-lamp252
Low Beam
High Beam
Installation Instructions
it comes with a driver box. and installation of bulb is same as other H4 bulbs.
  1. remove the connector from existing H4 bulb.
  2. remove the rubber
  3. release the clip from housing
  4. remove the existing bulb from housing
  5. remove the heatsink from philips LED bulb
  6. insert the bulb into housing
  7. connect the clip into housing
  8. attach the rubber
  9. attach the heatsink
  10. attach the one side of philips LED bulb wire connector to driver box and other cable to main connector (which was previously attached with bulb directly).
no cutting or modification in wiring.
  • created
    Mar '17
  • last reply
    Mar '17
  • 6
    replies
  • 5.3k
    views
  • 5
    users
  • 2
    likes
  • 8
    links
It is not available in Pakistan. in International Market its price varies from $140 to $230
