Sep 2013
1 / 6
Sep 2013
Oct 2013
Hi,
Up for sale is a Profec B spec II electronic boost controller.
  • LCD screen to monitor boost pressure in real time.
  • Readout now in kPa or PSI. (100kPa = 1.01972kg/cm2 = 1.5psi)
  • Controls boost up to 43 psi (This may vary on different turbo systems)
  • There are 2 preset settings that can be selected by a single switch.
  • The response and the consistency of the boost can be adjusted by using the GAIN, START BOOST setting.
  • A built in warning feature will alert the driver when the boost exceeds the set boost pressure with an alarm and a message in the display.
  • When the warning feature is activated, the LIMITER feature can lower the boost to a safe pressure.
  • PEAK boost feature will allow the user to check the highest boost recorded.
demand: Rs. 26,000 Negotiable.
Contact 0333-9000 nine three nine
8 days later
21 days later
